How to connect ASIC?
15/12/2022
All ASICs that work on the SHA256, Scrypt, Ethash, Etchash, kHeavyHash, RandomX, Blake3, Sha512256d algorithms (BTC+FB, FB, XEC, DGB, BCH, LTC+DOGE+BEL+PEP, KASPA, SEDRA, ETHW, ETC, OCTA, XMR, ALPH, RXD) can be connected to Kryptex pools.
Mine anything — Get Bitcoin!
On Kryptex Pool, you have the option to mine various altcoins and receive payments in Bitcoin, Ether, USDT starting from $1.5, AdvCash, or Amazon eGift cards. Connect now and mine with automatic exchange to BTC!
Supported models list that will work on Kryptex Pool:
BTC Bitcoin ASICs
FB Fractal Bitcoin ASICs
XEC eCash ASICs
DGB DigiByte ASICs
BCH Bitcoin Cash ASICs
LTC Litecoin + DOGE + BEL ASICs
Ethash (ETHW, ETC, OCTA) ASICs
The full list of ASICs that work on the Ethash algorithm can be viewed on this website.
kHeavyHash KASPA, SEDRA ASICs
Blake3 Alephium ALPH ASIC / FPGA
Sha512256d Radiant RXD ASIC / FPGA
RandomX Monero XMR ASIC
Which ASIC to choose?
For which coin? What will be the income? Will I be able to pay off?
Experts from ASICMINERCOMPARE help miners with all these questions. They:
  • regularly study the ASIC and FPGA market;
  • analyze prices and profitability of ASICs;
  • make lists of the best suppliers and sellers;
  • will help to choose an ASIC for your needs.
Choose an ASIC or compare the profitability of the models you are interested in the Best ASIC miners table or at https://asicminercompare.com
How to connect?
To get started, select the coin you are going to mine and the pool where you will mine.
To connect ASIC to Kryptex pools you need to know:
  1. IP address of your ASIC in your local network (you can find it in your router settings)
  2. The URL of the pool you are going to connect your device.
  3. Crypto wallet’s address where you will receive the payout from the pool.
If you don't have a crypto wallet for payouts yet, you need to create one. In our article we told how to choose and register a cryptocurrency wallet.
ASIC setup
Once you are logged into your ASIC device cabinet, go to the configuration (settings) tab.
The settings menu may slightly differ for different manufacturers, but the meaning and basic settings will be approximately the same for any model.
You will see the following fields:
  • URL (Address) — here you need to specify the address of the pool to which you are connecting.
  • USER (WORKER) — here you need to specify the wallet and the name of your device.
  • PASS (Password) — here you need to specify the password to connect to the pool.
  • COIN (Algorithm) — if applicable. Here, you should specify the algorithm or coin you will mine.
Pool connection settings:
Coin Algorithm URL - Pool address Wallet format Password
BTC+FB BTC or SHA256 btc.kryptex.network:7777 or stratum+tcp://btc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
FB BTC or SHA256 fb.kryptex.network:7777 or stratum+tcp://fb.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
XEC BTC or SHA256 xec.kryptex.network:7777 or stratum+tcp://xec.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
DGB BTC or SHA256 dgb.kryptex.network:7777 or stratum+tcp://dgb.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
BCH BTC or SHA256 bch.kryptex.network:7777 or stratum+tcp://bch.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
LTC+DOGE+BEL+PEP Scrypt ltc.kryptex.network:7777 or stratum+tcp://ltc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
KASPA KAS or kHeaveHash kas.kryptex.network:7777 or stratum+tcp://kas.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
SDR KAS or kHeaveHash sdr.kryptex.network:7777 or stratum+tcp://sdr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETC ETC or ETCHASH etc.kryptex.network:7777 or stratum+tcp://etc.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ETHW ETH or ETHASH ethw.kryptex.network:7777 or stratum+tcp://ethw.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
OCTA ETH or ETHASH octa.kryptex.network:7777 or stratum+tcp://octa.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
XMR XMR or RANDOMX xmr.kryptex.network:7777 or stratum+tcp://xmr.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
ALPH ALPH or Blake3Alephium alph.kryptex.network:7777 or stratum+tcp://alph.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
RXD RXD or Sha512256d rxd.kryptex.network:7777 or stratum+tcp://rxd.kryptex.network:7777 WALLET_ADDRESS.WORKER_NAME x or leave blank
WALLET_ADDRESS - use your wallet address from a previously registered wallet.
WORKER_NAME - the name of ASIC, should be no more than 32 characters, written in Latin letters and without spaces. May contain numbers 0-9, as well as characters - and _. For example, ASIC_1
Get your payout!
Payouts processing hourly once reaching the payout threshold.
  1. Open the page with the pool you are mining to and enter your crypto wallet’s address;
  4. In the "Ip Address" cell, enter the IP address of the worker whose name the site prompts you. The IP address must end the same as indicated in the prompt on the site (see the last digits). Please note that you need an external IP address, but not a local one — they are different.
  5. Press the “Submit” button.
