Connection
How To Mine eCash XEC
10/11/2026
Check our YouTube Video how to mine eCash XEC
eCash (XEC) is a cryptocurrency built on Bitcoin ABC, rebranded in 2021. It leverages the Avalanche protocol for fast and secure transactions, supports tokens and NFTs. Focused on scalability and user-friendliness, it’s ideal for DeFi and applications. Leading exchanges endorse the coin, and miners appreciate its high profitability.
Kryptex Pool supports mining eCash XEC using various SHA256 ASIC devices.
GPUs and CPUs, however, aren't capable of mining eCash XEC, as they simply lack the necessary processing power.
Supported miners
Kryptex eCash XEC Pool supports all well-known miner manufacturers:
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Aladdin
  • Bitfury
  • Ebang
  • Aixin
Create An eCash XEC Wallet
To start eCash XEC mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
Alternatively, you can mine directly to your Kryptex account and withdraw cryptocurrency in various ways: BTC (including Lightning), ETH, LTC, USDT (BEP20, TRC20), USDC (Polygon), BNB (Smart Chain), TRX. The process is explained in detail in our article.
    • URL of the eCash XEC mining pool: stratum+tcp://xec.kryptex.network:7036
    • For instance: ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9.Antminer_S21 where: ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9 — represents the eCash XEC wallet address. Antminer_S21 is the chosen name for your worker in free form.
    • Ensure you use a eCash XEC wallet address.
  1. Visit the eCash XEC Kryptex Pool at https://pool.kryptex.com/xec.
Payouts
  1. Open the eCash XEC pool page and enter your mining address;
  5. Press the “Submit” button.
