연결
How to mine QUAI Scrypt
2026. 9. 15.
Check our YouTube Video how to mine QUAI Scrypt
QUAI Scrypt — a Scrypt algorithm fork of the QUAI coin within the QUAI SOAP project.
Quai is a high-throughput cryptocurrency. It runs on its own blockchain and processes over 50,000 transactions per second without compromising decentralization. The value of the project lies in fast and low-cost transactions. Its goal is to build a decentralized global payment system capable of handling massive transaction volumes.
SOAP (Subsidized Open-market Acquisition Protocol) is designed to ensure the resilience and security of the QUAI network. QUAI SOAP sells partner-chain tokens on the market and buys QUAI. Miners are rewarded in QUAI coins for their work.
⛏️ Mine QUAI Scrypt — https://pool.kryptex.com/quai-scrypt
🔗 QUAI Scrypt Pool URLs:
  • Global: stratum+tcp://quai-scrypt.kryptex.network:7045
  • EU: stratum+tcp://quai-scrypt-eu.kryptex.network:7045
  • US: stratum+tcp://quai-scrypt-us.kryptex.network:7045
  • SG: stratum+tcp://quai-scrypt-sg.kryptex.network:7045
  • RU: stratum+tcp://quai-scrypt-ru.kryptex.network:7045
Supported Miners
To mine QUAI Scrypt, you need a Scrypt ASIC.
  • Bitmain Antminer
  • Goldshell
  • ElphaPex
  • Fluminer
  • Innosilicon
  • FusionSilicon
  • BW Miner
This is only a partial list of ASIC manufacturers. Kryptex Pool supports any Scrypt ASIC miner.
QUAI can also be mined with SHA256 ASICs or GPUs using the QUAI ProgPow and QUAI KawPow algorithms.
Register a QUAI Wallet
To mine QUAI Scrypt, you need to register a QUAI wallet address.
👉 Detailed guide on how to register a QUAI wallet address.
We strongly recommend using only personal wallets for mining and long-term storage.
Connecting to the QUAI Scrypt Pool: Step-by-Step Guide
Region URL Wallet Template Password
Global quai-scrypt.kryptex.network:7045 wallet.worker x or leave blank
EU quai-scrypt-eu.kryptex.network:7045 wallet.worker x or leave blank
US quai-scrypt-us.kryptex.network:7045 wallet.worker x or leave blank
SG quai-scrypt-sg.kryptex.network:7045 wallet.worker x or leave blank
RU quai-scrypt-ru.kryptex.network:7045 wallet.worker x or leave blank
    • URL of QUAI scrypt mining pool: stratum+tcp://quai-scrypt.kryptex.network:7045
    • For instance: 0x002fb1466602cdca5b4b4010e64154443417bccd.L7 where: 0x002fb1466602cdca5b4b4010e64154443417bccd — represents the QUAI wallet address. L7 is the chosen name for your worker in free form.
  4. Replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
  1. Open the QUAI scrypt Kryptex Pool — https://pool.kryptex.com/quai-scrypt
Payouts
  5. Press the “Submit” button.
