How to mine Fractal Bitcoin FB
2026. 5. 11.
Check our YouTube Video how to mine Fractal Bitcoin FB
Fractal Bitcoin is a cryptocurrency designed to enhance transaction anonymity and security compared to traditional Bitcoin. By leveraging an advanced blockchain structure, Fractal Bitcoin focuses on privacy and decentralization. Over time, the project has gained attention from those seeking more private methods for exchanging digital assets.
Kryptex Pool supports mining Fractal Bitcoin using various SHA256 ASIC devices. GPUs and CPUs, however, aren't capable of mining Fractal Bitcoin, as they simply lack the necessary processing power.
Supported miners
Kryptex FB Pool supports all well-known miner manufacturers:
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Aladdin
- Bitfury
- Ebang
- Aixin
Create a Fractal Bitcoin FB Wallet
To start Fractal Bitcoin mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
- Access the control panel of your ASIC.
- Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
- Input the following settings:
- URL of the FB mining pool:
stratum+tcp://fb.kryptex.network:7013 - Worker: Enter the wallet address for mining and the worker name in the format
1JnCDKc1tnKSkj1CMhegTxS3kRpsw5msWv.Antminer_S9Dwhere:1JnCDKc1tnKSkj1CMhegTxS3kRpsw5msWv— represents the Fractal Bitcoin wallet address.Antminer_S9Dis the chosen name for your worker in free form. - Ensure you use a Fractal Bitcoin wallet address.
- Password: This field is optional. You can either enter
xor leave it blank.
- If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
- Save and apply the settings, then reboot the ASIC.
Visit the FB Kryptex Pool at https://pool.kryptex.com/fb.
Payouts
Open the FB pool page and enter your mining address;
Press the “Settings” button.
Press the “Submit” button.
