Pearl Miners Overview
2026. 11. 10.
⛏️ Pearl (PRL) is mined on modern GPUs — Nvidia RTX 2000-series and newer, AMD RX 6000-series (RDNA2), and Intel Arc — using the pearlhash algorithm. This overview covers the GPU miners for Pearl and the ready commands to connect them to Kryptex Pool.
👉 Mine Pearl on Kryptex Pool: ready miner configs, HiveOS templates.
Pearl pool stratum addresses
Connect to the server closest to you — the lower the ping, the faster your shares reach the pool and the fewer stale or rejected shares you get. Multiple server regions also help when mining is restricted in your area: if one endpoint is blocked or unreachable, switch to another and keep mining.
| Region | Stratum address |
| Global | prl.kryptex.network:7048 |
| Europe | prl-eu.kryptex.network:7048 |
| North America | prl-us.kryptex.network:7048 |
| South America | prl-br.kryptex.network:7048 |
| Singapore | prl-sg.kryptex.network:7048 |
| Hong Kong | prl-hk.kryptex.network:7048 |
| Russia | prl-ru.kryptex.network:7048 |
| Middle East | prl-ae.kryptex.network:7048 |
For SSL, use port 8048 on the same hosts.
In the commands below, replace WALLET_ADDRESS / WORKER_NAME with your PRL wallet and worker. For auto-conversion to BTC, use your Kryptex Mining Username instead of the wallet; for SOLO, add the solo: prefix.
WildRig setup for PRL
WildRig Multi is a popular multi-algorithm GPU miner. For Pearl on Kryptex Pool we recommend SRBMiner-MULTI or BzMiner instead — these are the miners we support, and they cover Nvidia, AMD and Intel Arc. If you came looking for a WildRig PRL setup, use one of the configs below.
SRBMiner setup for PRL
SRBMiner-MULTI (Windows and Linux) mines Pearl on the pearlhash algorithm and supports Nvidia and AMD RX 6000-series (RDNA2) cards.
SRBMiner-MULTI.exe --disable-cpu --algorithm pearlhash --pool prl.kryptex.network:7048 --wallet WALLET_ADDRESS.WORKER_NAME
BzMiner setup for PRL
BzMiner runs on Nvidia, AMD and Intel Arc:
bzminer -a pearl -p stratum+tcp://prl.kryptex.network:7048 -w WALLET_ADDRESS/WORKER_NAME --nvidia 1 --amd 1 --intel 1 --igpu 0 --cpu 0 --cpu_threads 0 --nc 1
On Linux, run the same command as ./bzminer.
PeakMiner setup for PRL
PeakMiner (Nvidia) picks TCP or SSL automatically by the port:
peakminer --coin pearl -o prl.kryptex.network:7048 -u WALLET_ADDRESS/WORKER_NAME
On Linux, run it as ./peakminer.
ARCMiner setup for PRL
ARCMiner is built for Intel Arc GPUs:
arc-miner.exe --pool stratum+tcp://prl.kryptex.network:7048 --wallet WALLET_ADDRESS --worker WORKER_NAME
lpminer setup for PRL
lpminer (Nvidia) is the simplest option on Windows:
lpminer.exe --algo pearl --pool stratum+tcp://prl.kryptex.network:7048 --wallet WALLET_ADDRESS.WORKER
All of these miners run on HiveOS with ready templates. Full step-by-step setup: 👉 How to mine Pearl (PRL).
- Support Ticket.
- Telegram Support.
- Discord Support.
- Email support at support@kryptex.com.
