채굴
Pearl Mining Pools
2026. 11. 10.
⛏️ Pearl (PRL) is a GPU-mined Proof-of-Useful-Work coin on the pearlhash algorithm, supported by all the popular miners — SRBMiner-MULTI, BzMiner, PeakMiner, ARCMiner and lpminer — on Nvidia, AMD (RX 6000 RDNA2) and Intel Arc. This page lists the main Pearl mining pools and how they compare, so you can pick where to mine PRL.
👉 Mine Pearl on Kryptex Pool: ready miner configs, HiveOS support.
Pearl (PRL) mining pools
Criterion Kryptex Pool PearlHash HeroMiners PearlFortune LuckyPool
Payouts 🟢 PRL + BTC, USDT, ETH, LTC 🟡 PRL 🟡 PRL 🟡 PRL 🟡 PRL
Geo regions 🟢 Yes 🟡 Limited 🟢 Yes 🟡 Limited 🟢 Yes
Auto-conversion to BTC 🟢 Yes 🔴 No 🔴 No 🔴 No 🔴 No
Ready configs + HiveOS 🟢 Yes 🟡 Limited 🟡 Limited 🟡 Limited 🟡 Limited
Telegram monitoring bot 🟢 Yes 🔴 No 🟡 Limited 🔴 No 🟡 Limited
Kryptex
Kryptex Pool is an open, global Pearl pool for GPU miners. Mine PRL in PPS+ or SOLO mode, connect to the nearest of 8 regional servers, and get paid in PRL — or mine to your Kryptex account: Pearl is converted to BTC automatically, and you can withdraw in BTC, USDT, ETH, LTC and more. It ships ready configs for SRBMiner-MULTI, BzMiner, lpminer and HiveOS, a Telegram monitoring bot, and a 1 PRL minimum payout. No registration is needed to mine to a PRL wallet.
Kryptex — the best Pearl mining pool
Kryptex Pearl servers
Connect to the nearest of 8 servers — the lower the ping, the faster your shares reach the pool. Multiple server regions also help when mining is restricted in your area: if one endpoint is blocked or unreachable, just switch to another and keep mining.
Region Stratum address
Global prl.kryptex.network:7048
Europe prl-eu.kryptex.network:7048
North America prl-us.kryptex.network:7048
South America prl-br.kryptex.network:7048
Singapore prl-sg.kryptex.network:7048
Hong Kong prl-hk.kryptex.network:7048
Russia prl-ru.kryptex.network:7048
Middle East prl-ae.kryptex.network:7048
For SSL, use port 8048.
PearlHash
PearlHash (pearlhash.xyz) is a newer pool, close to the Pearl project and named after the pearlhash algorithm. It's closed-source with a focused feature set, and pays out in PRL.
HeroMiners
HeroMiners is a long-running multi-coin pool that also runs a Pearl (PRL) pool with PPS+ and SOLO modes and servers in several regions. The interface is functional if a little classic, and Pearl payouts are in PRL.
PearlFortune
PearlFortune is one of the larger Pearl pools, with public network stats. Its fee is 5%, payouts are in PRL only, and server choice is limited.
LuckyPool
LuckyPool (pearl.luckypool.io) runs a Pearl (PRL) pool on global low-latency servers, with PROP and SOLO modes. Payouts are in PRL.
Other Pearl pools include K1Pool and Coin-miners.
Start mining Pearl
Point your Nvidia, AMD or Intel Arc GPU at Kryptex Pool and mine Pearl. Ready commands for every miner are in the How to mine Pearl (PRL) guide.
