FAQ
How to start mining on Kryptex Pool
30.03.2026
To start mining on Kryptex Pool you need powerful PC, ASIC miner, or FPGA miner.
If you're mining on a PC, it needs to have a powerful processor and/or a video card from 2016 or newer. The video card should have at least 4 GB of GDDR5 memory or better. Older processors and video cards don’t support the necessary instructions for profitable mining.
Step One — Create a Wallet for Your Coin
For each coin, you can use any wallet format that suits you: hardware, local/mobile wallet, or generate an address on a cryptocurrency exchange.
We do not recommend mining directly to an exchange.
If you mine to an exchange, you do so at your own risk. Not your keys — not your crypto!
Step Two — Choose a Coin to Start Mining
Connect to pools — pool.kryptex.com
You can find the setup instructions for the selected coin on its page, located in the first column of the table.
Coin Wallet Pool Address Wallet Format Password CPU/GPU/ASIC
BTC+FB BTC Wallet btc.kryptex.network:7014 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
FB FB Wallet fb.kryptex.network:7013 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
QUAI-SHA256 QUAI Wallet quai-sha256.kryptex.network:7044 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
BC2 BC2 Wallet bc2.kryptex.network:7041 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
XEC XEC Wallet xec.kryptex.network:7036 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
DGB DGB Wallet dgb.kryptex.network:7037 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
BCH BCH Wallet bch.kryptex.network:7015 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
BSV BSV Wallet bsv.kryptex.network:7047 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
ZEC ZEC Wallet zec.kryptex.network:7042 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
LTC+DOGE+BEL+PEP LTC Wallet ltc.kryptex.network:7016 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
QUAI-SCRYPT QUAI Wallet quai-scrypt.kryptex.network:7045 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
ETC ETC Wallet etc.kryptex.network:7033 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
ETHW ETHW Wallet ethw.kryptex.network:7034 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
OCTA OCTA Wallet octa.kryptex.network:7032 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
RXD RXD Wallet rxd.kryptex.network:7012 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
ALPH ALPH Wallet alph.kryptex.network:7010 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
KAS KASPA Wallet kas.kryptex.network:7011 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
XTM-SHA3X XTM Wallet xtm-sha3x.kryptex.network:7039 WALLET_ADDRESS.WORKER_NAME x or nothing ASIC
QUAI-KAWPOW QUAI Wallet quai-kawpow.kryptex.network:7043 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
XTM-C29 XTM Wallet xtm-c29.kryptex.network:7040 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
IRON IRON Wallet iron.kryptex.network:7017 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
XEL XELIS Wallet xel.kryptex.network:7019 WALLET_ADDRESS.WORKER_NAME x or nothing GPU/CPU
CFX CFX Wallet cfx.kryptex.network:7027 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
NEXA NEXA Wallet nexa.kryptex.network:7026 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
ERGO ERGO Wallet erg.kryptex.network:7021 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
RVN RVN Wallet rvn.kryptex.network:7031 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
XNA XNA Wallet xna.kryptex.network:7024 WALLET_ADDRESS.WORKER_NAME x or nothing GPU
XMR XMR Wallet xmr.kryptex.network:7029 WALLET_ADDRESS.WORKER_NAME x or nothing CPU/ASIC
ZEPH ZEPH Wallet zeph.kryptex.network:7030 WALLET_ADDRESS.WORKER_NAME x or nothing CPU
SAL SAL Wallet sal.kryptex.network:7028 WALLET_ADDRESS.WORKER_NAME x or nothing CPU
XTM-RX XTM Wallet xtm-rx.kryptex.network:7038 WALLET_ADDRESS.WORKER_NAME x or nothing CPU
  1. Choose the coin to mine based on your device type.
  • GPU — You can mine coin with a Graphics Card.
  • CPU — You can mine coin with a Processor.
  • ASIC (FPGA) — You can mine coin with an ASIC or FPGA.
  1. Register your cryptocurrency wallet for payouts.
  2. Configure your miner or ASIC.
    • Enter the pool address in the miner's batch file settings or in the ASIC settings.
    • Enter your previously registered wallet address in the miner's batch file settings or in the ASIC settings.
    • Specify the worker name after the wallet address, separated by a dot “.” or a slash “/”. The worker name must be no longer than 32 characters, using only Latin letters and/or numbers, with no spaces or special characters. For example, MyRig1.
  3. Save the settings and start mining.
How to receive payouts?
Payouts are processed every hour once the payout threshold is reached.
  1. Open the pool page and enter the wallet address you are mining to.
  2. Go to the Settings tab.
  3. Specify your desired payout threshold in the Payout Threshold field.
    • The minimum and maximum thresholds are listed on the main pool page.
    • There is no transaction fee on the pool — Kryptex covers it for you 🖤.
  4. In the IP Address field, enter the IP address of your worker as shown on the website.
    • The IP address should match the one displayed on the site (check the last few digits).
    • You can find your IP: https://ipinfo.io/ip
  5. Click Apply.
Your payouts will now be processed automatically once the threshold is met.
