Қосылу
HiveOS dual mining
30.03.2026
Earlier, we provided instructions on how to connect HiveOS to Kryptex pools, which means we won't delve into the details of that process here.
Instead, let's discuss dual mining, which can be set up in just a few minutes.
You can also try dual mining ETC + KASPA, ETHW + KASPA, ETC + IRON, ETHW + IRON, ERG + IRON, CFX + IRON.
Already using dual-mining? Increase your profit! We will tell you how to distribute the hashrate between algorithms and optimize dual-mining.
Create a flight sheet
  1. First, select your primary coin. In our example, we've chosen ERGO, but feel free to choose another coin like ETC if you prefer. Here's how to fill out the flight sheet template:
    • Select the coin you want to mine, in this case, ERGO.
    • Specify the wallet address for that coin. If you haven't added it yet, simply click the "Add Wallet" button.
    • Choose a Kryptex pool from the list.
    • Select a miner to use. In our case, we're using Gminer for our Nvidia graphics card.
    • Click the "Setup Miner Config" button located next to the miner.
  2. Next, click on the "Second coin" button and enter the following information in the provided fields:
    • Second hash algorithm — select kheavyhash for KASPA.
    • Wallet and template worker — input your wallet address for KASPA and specify the worker's name separated with /. Note that the KASPA wallet should begin with kaspa:. Here's an example: kaspa:qp8u4wzjhy5m8h63cz7kvczpdksd3cqghptf5nakghmue5ffqlvyusw30dgpg/hiveOSrig
    • Pool server — enter the pool address, which is kas.kryptex.network
    • Port — input 7011
    • Password — input x
    • Finally, click the "Apply changes" button.
  3. Name the flight sheet and save it.
  4. Then, everything is as usual:
    • Choose the mining rig and the worker.
    • Select the created flight sheet.
    • Click on the rocket icon to finish.
Any questions left?
  2. How to connect HiveOS to Kryptex.
  4. How to make a payout?
  5. Mining monitoring bot.
  6. Need support?
