Қосылу
30.03.2026
Goldshell has introduced the world's first ALPH (Blake3) mining ASICs — Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III. These ASICs has high energy efficiency, high income and low noise, which makes them suitable for home use.
Kryptex Pool offers full support of Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III so you can expect exceptional efficiency and a consistent profit when mining ALPH.
Join us today at https://pool.kryptex.com/alph
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III — Characteristics and Size
AL BOX Blake3 ALPH 360 GH/s (±5%) 180 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
AL BOX II Blake3 ALPH 720 GH/s (±5%) 360 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
AL BOX II PLUS Blake3 ALPH 1 TH/s (±5%) 480 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
AL BOX III Blake3 ALPH 1,25 TH/s (±5%) 600 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Hashrate
Goldshell AL BOX ASICs’ can make 360 Gh/s ±5% on Blake3 (ALPH) algorithm, which is equal to the hashrate of 60 RTX 4090, consuming 93 times less electricity — only 180 watts versus 16800 watts.
Model AL BOX III triples the result — 1,25 TH/s (±5%) with a consumption of only 600 Watts.
What to Mine on Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III?
Goldshell AL BOX, AL BOX II, AL BOX III ASICs can mine coins using Blake3 algorithm. You can’t reconfigure them for any other algorithms.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Profitability
Currently, the daily profitability of Goldshell AL BOX is about ~ 1,5$, Goldshell AL BOX III ~5$ excluding electricity costs.
Check the profitability of Goldshell AL BOX III ASIC on the mining calculator.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Settings
Coin URL Miner Name Password
ALPH stratum+tcp://alph.kryptex.network:7010 ALPH_WALLET_ADDRESS.WORKER_NAME x or leave blank
1B7fgnoznDCoRJQBZqKLU2DBBfRBUEPNeBCpWFLTctwmK.goldshell where
  • 1B7fgnoznDCoRJQBZqKLU2DBBfRBUEPNeBCpWFLTctwmK — your wallet address,
  • goldshell — Your ASIC name.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Firmware Update
