How to mine Ethereum Classic (ETC)
30.03.2026
For Ethereum Classic mining you need ASIC, mining on graphics cards will be useless due to the high difficulty of the network.
- Antminer E9 Pro
- Jasminer X16-P, X16-Q, X4, X4-Q, X4-1U
- iPollo V1, V1 mini, V1 Mini SE, V1 Mini SE Plus, X1
- Bombax EZ100, EZ100-C
- ForestMiner EPU 1-C, 2-C, XC
Here is a complete list of ASIC models for Ethereum Classic (ETC) mining.
For ETC mining, an Ethash-ASIC with at least 4GB of memory is required.
Step one — register a wallet
- Register the wallet https://metamask.io/.
Detailed instruction on How to create Ethereum Classic (ETC) wallet. - You can trade Ethereum Classic (ETC) with on of the following exchangers: Binance, Gate.io, MEXC, CoinEx, KuCoin, ByBit.
We recommend you mine to your wallet and then transfer the cryptocurrency to the exchange. That will be more reliable.
Step two — setup your ASIC
Quick-start mining settings
Ethereum Classic Pool — https://pool.kryptex.com/etc
Pool address: stratum+tcp://etc.kryptex.network:7033
Wallet format: WALLET_ADDRESS/WORKER_NAME
Example of setting up ASIC for Ethereum Classic — Bitmain Antminer E9 Pro
Open Ethereum Classic pool page https://pool.kryptex.com/etc
Paste your wallet address into the search field, and press Enter.
You will see a page with the statistics of your wallet and your mining rigs.
Step Four — payout
Press the “Settings” button.
Set the desired “Payment Threshold”. Minimum and maximum payment threshold mentioned at the pool home page. There is no payout fee — Kryptex pays it for you 🖤
In the "Ip Address" cell, enter the IP address of the worker whose name the site prompts you. The IP address of your mining rig. The IP address must end the same as indicated in the prompt on the site (see the last digits). Learn your IP here https://ipinfo.io/ip
Press the “Submit” button.
🤯Too complicated?
Contact us via website support, the private message on Telegram, or ask for help at our Discord.
