ASIC iBeLink BM-KS Max
13.02.2024
iBeLink has introduced the most powerful ASIC miner for KASPA and SEDRA (kHeavyHash) — iBeLink BM-KS Max. This ASIC outperforms the most powerful rivals by 15-20%.
Kryprex Pool offers full support of iBeLink BM-KS Max ASIC, so you can expect exceptional efficiency and a consistent profit when mining KASPA and SEDRA.
Join us today:
Manufacturer — iBeLink
Model — BM-KS Max
Algorithm — kHeavyHash
Coins — KASPA, SEDRA
Hashrate — 10,5 Th/s ±5%
Power Consumption — 3400 Watt ±3%
Dimensions — 34 х 19 х 29,3 cm
Weight — 12,2 kg
iBeLink BM-KS Max ASICs’ can make 10,5 Th/s ±5% on kHeavyHash (KASPA) algorithm, which is equal to the hashrate of 105 Iceriver KS0, consuming 2 times less electricity — only 3400 watts versus 6825 watts.
iBeLink BM-KS Max can only mine kHeavyHash algorithm: KASPA and SEDRA coins. You can’t reconfigure them to any other algorithms.
Currently, the daily profitability of iBeLink BM-KS Max is about ~ 40$, excluding electricity costs.
Check the profitability of iBeLink BM-KS Max ASICs on the mining calculator.
iBeLink BM-KS Max Settings
Go to “Settings → Pool Setting” tab to setup your ASIC.
Coin Pool URL Worker Password
Worker — The wallet address and worker name specified like this:
kaspa:qzyjntttd55mpxdk54g6jryjwa46lgptwddtnqlxueg3val9j4z5c282f2elf.ibelink where
  • ibelink — Your ASIC name.
Monitor your ASIC’s work on the “Status” page. Here you will see your hashrate, statistics of accepted shares and all related information.
  1. Go to the manufacturer's website and download the required firmware: https://en.ibelink.com.hk/xiazai/
  2. Open the page for updating “Upgrade”, select the downloaded update.
