Қосылу
ASICs Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+
30.03.2026
Dragonball has released kHeavyHash ASICs for the profitable KASPA and SEDRA coins. Kryptex PPS+ Pool is the best and almost the only pool that has tested and supports Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ ASICs.
Join us today:
Dragonball Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ — Specifications and Size
KS6 kHeavyHash KAS, SDR 10,5 TH/s (±5%) 3,4 kWt (±10%) 36 x 18,5 x 29 cm 14,5 kg
KS6 S kHeavyHash KAS, SDR 10 TH/s (±5%) 3,6 kWt (±10%) 36 x 18,5 x 29 cm 14,5 kg
KS6 Pro kHeavyHash KAS, SDR 10,5 TH/s (±5%) 3,6 kWt (±10%) 36 x 18,5 x 29 cm 14,5 kg
KS6 Pro+ kHeavyHash KAS, SDR 11 TH/s (±5%) 3,6 kWt (±10%) 36 x 18,5 x 29 cm 14,5 kg
Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ Hashrate
The Dragonball KS6 series models have a small spread in hash rate and consumption.
The flagship model Dragonball KS6 Pro+ can make 11 Th/s on kHeavyHash algorithm, which is equal to the hashrate of 110 KS0 ASICs, consuming 2 times less — only 3,6 kW versus 7,15 kW.
What to Mine on Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ ASICs?
Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ ASICs can only mine kHeavyHash algorithm: KASPA and SEDRA coins. You can’t reconfigure them to any other algorithms.
Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ Profitability
Currently, the profitability of Dragonball ASICs may vary from 39$/day up to 44$/day, depending on the model and excluding electricity costs.
Profitability can sharply decrease with the increase of the KASPA network difficulty.
Model Coin Hashrate Consumption Profit w/o El. Price
KS6 KAS, SDR 10,5 TH/s (±5%) 3,4 kWt (±10%) ~42$ / day
KS6 S KAS, SDR 10 TH/s (±5%) 3,6 kWt (±10%) ~39$ / day
KS6 Pro KAS, SDR 10,5 TH/s (±5%) 3,6 kWt (±10%) ~42$ / day
KS6 Pro+ KAS, SDR 11 TH/s (±5%) 3,6 kWt (±10%) ~44$ / day
Check the profitability of Dragonball KS6 Pro on the mining calculator.
Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ ASICs Settings
Go to “Miner Configuration” tab to setup your ASIC.
Coin URL Worker Password
KASPA stratum+tcp://kas.kryptex.network:7011 KASPA_WALLET_ADDRESS.WORKER_NAME x or leave blank
SEDRA stratum+tcp://sdr.kryptex.network:7018 SEDRA_WALLET_ADDRESS.WORKER_NAME x or leave blank
Wallet.Worker — The wallet address and worker name specified like this:
kaspa:qqkfeg7a5h9fq3wm0uyum6lv4e3y0xdszs0mq27p0wewre0re5azjrhvuz5e8.dragonball where
  • kaspa:qqkfeg7a5h9fq3wm0uyum6lv4e3y0xdszs0mq27p0wewre0re5azjrhvuz5e8 — your wallet address, starting with kaspa:
  • dragonball — Your ASIC name.
Click "Save&Apply" to save your settings and start mining.
Monitor your ASIC’s work on the “Miner Status” page. Here you will see your hashrate, statistics of accepted shares and all related information.
Dragonball KS6, KS6 S, KS6 Pro, KS6 Pro+ Firmware Update
  1. Go to the manufacturer's website and download the required firmware: https://dragonballminer.com/en/software/
  2. Open the page for updating “System → Firmware upgrade”, select the downloaded update.
