Bağlantı
How To Mine Zcash ZEC
15.09.2026
Check our YouTube Video how to mine Zcash ZEC
Zcash (ZEC) is a cryptocurrency designed as a privacy-focused alternative to Bitcoin, with a strong emphasis on anonymity and security. It’s built on the zk-SNARKs protocol, which enables shielded transactions — hiding the sender, receiver, and transaction amount. Zcash doesn’t aim to replace Bitcoin, but rather offers a choice for those who value confidentiality in digital payments. The developers are actively engaged with the community, continuously supporting ecosystem growth and implementing new innovations.
Kryptex Pool supports mining Zcash ZEC using various EquiHash ASIC devices.
GPUs and CPUs, however, aren't capable of mining Zcash ZEC, as they simply lack the necessary processing power.
Supported miners
Kryptex Zcash ZEC Pool supports all well-known miner manufacturers:
  • Bitmain Antminer Z9mini, Z9, Z11, Z15, Z15Pro
  • Innosilicon A9, A9+, A9++
Create Zcash ZEC Wallet
To mine Zcash ZEC, you willl need a wallet address.
You can create a personal Zcash ZEC wallet using convenient multicurrency wallet TrustWallet, or get a wallet address from a cryptocurrency exchange MEXC, Binance, Gate.io, KuCoin.
For mining and long-term storage, we strongly recommend using a personal wallet.
Mine Zcash (ZEC) — get paid in Bitcoin (BTC) directly to your Kryptex account. Your ZEC earnings are automatically converted to BTC. You can withdraw your crypto in multiple ways: BTC, ETH, LTC, TRX, BNB, USDT, USDC — or to your Volet wallet.
Connecting to the Zcash ZEC: Step-by-Step Guide
Region URL Wallet Template Password
Global zec.kryptex.network:7042 wallet.worker x or leave blank
EU zec-eu.kryptex.network:7042 wallet.worker x or leave blank
US zec-us.kryptex.network:7042 wallet.worker x or leave blank
SG zec-sg.kryptex.network:7042 wallet.worker x or leave blank
RU zec-ru.kryptex.network:7042 wallet.worker x or leave blank
Let's take the Bitmain Antminer Z15 Pro ASIC as an example.
    • URL of the Zcash ZEC mining pool: stratum+tcp://zec.kryptex.network:7042
    • For instance: t1ScU9R3YoZWPwwrm2jGSZtTpHKk9tw6ahU.Z15 where: t1ScU9R3YoZWPwwrm2jGSZtTpHKk9tw6ahU — represents the Zcash ZEC wallet address. Z15 is the chosen name for your worker in free form.
    • Ensure you use a Zcash ZEC wallet address.
  1. Visit the Zcash ZEC Kryptex Pool at https://pool.kryptex.com/zec.
Payouts
  1. Open the Zcash ZEC pool page and enter your mining address;
  5. Press the “Submit” button.
