Bağlantı
ASIC Goldshell XT BOX
13.05.2026
Goldshell has launched the world’s first ASIC miners for Tari XTM SHA3X — the Goldshell XT series. These devices offer high energy efficiency, strong profitability when mining Tari XTM, and low noise levels, making them suitable for home use.
Kryptex Pool is the top choice for mining Tari XTM SHA3X, offering full support for Goldshell XT BOX miners, excellent efficiency, and stable earnings.
⛏️ Start mining Tari XTM SHA3X — https://pool.kryptex.com/xtm-sha3x
🔗 Tari XTM SHA3X Pool URLs:
  • Global: xtm-sha3x.kryptex.network:7039
  • EU: xtm-sha3x-eu.kryptex.network:7039
  • US: xtm-sha3x-us.kryptex.network:7039
  • SG: xtm-sha3x-sg.kryptex.network:7039
  • RU: xtm-sha3x-ru.kryptex.network:7039
Miner Name — your Tari XTM wallet address
Example: 12NkgEiiRvsCyKkKmKE2t46fjtZz1i9iZq19QUVs8zkPbEFuuKWzuYLtuohR3t9YEwGPwL8X1S3QZxtT5pt31AYwkAA.XT_BOX
For SOLO mining, add solo: before your wallet address in the ASIC settings
Example: solo:12NkgEiiRvsCyKkKmKE2t46fjtZz1i9iZq19QUVs8zkPbEFuuKWzuYLtuohR3t9YEwGPwL8X1S3QZxtT5pt31AYwkAA.XT_BOX
Goldshell XT BOX — Characteristics and Size
XT BOX SHA3X XTM 580 GH/s (±5%) 400 Watt (±5%) 15 х 19,8 х 9,6 cm 2,4 kg
Goldshell XT BOX Hashrate
The hashrate of the Goldshell XT BOX ASIC is 580 GH/s ±5% on the Tari XTM SHA3X algorithm.
What to Mine on Goldshell XT BOX?
Goldshell XT BOX ASICs can mine Tari XTM coin using SHA3X algorithm. You can’t reconfigure them for any other algorithms.
Goldshell XT BOX Profitability
Profitability depends on network difficulty, the current coin price, and your electricity cost. We recommend checking the actual profitability using our mining calculator, where you can also factor in your local electricity rates.
👉 Calculate Goldshell XT BOX profitability with our mining calculator
Goldshell XT BOX Settings
Region URL Miner Name Password
Global xtm-sha3x.kryptex.network:7039 XTM_WALLET_ADDRESS.WORKER_NAME x or leave blank
EU xtm-sha3x-eu.kryptex.network:7039 XTM_WALLET_ADDRESS.WORKER_NAME x or leave blank
US xtm-sha3x-us.kryptex.network:7039 XTM_WALLET_ADDRESS.WORKER_NAME x or leave blank
SG xtm-sha3x-sg.kryptex.network:7039 XTM_WALLET_ADDRESS.WORKER_NAME x or leave blank
RU xtm-sha3x-ru.kryptex.network:7039 XTM_WALLET_ADDRESS.WORKER_NAME x or leave blank
Miner Name — Your wallet address and worker name should be entered in the following format:
Where:
  • 12NkgEiiRvsCyKkKmKE2t46fjtZz1i9iZq19QUVs8zkPbEFuuKWzuYLtuohR3t9YEwGPwL8X1S3QZxtT5pt31AYwkAA is your Tari XTM wallet address
  • XT_BOX is the name of your ASIC miner, written using Latin letters and/or numbers
  • For SOLO mining, add solo: before your wallet address in the ASIC settings. Example: solo:12NkgEiiRvsCyKkKmKE2t46fjtZz1i9iZq19QUVs8zkPbEFuuKWzuYLtuohR3t9YEwGPwL8X1S3QZxtT5pt31AYwkAA.XT_BOX
Click “Apply” to save your settings and start mining.
You can monitor your ASIC’s performance on the Home page — including hashrate, accepted shares, and other relevant stats.
Goldshell XT BOX Firmware Update
