Подключение
ASICs Goldshell KA BOX, KA BOX Pro
13.05.2026
Goldshell has introduced a new home ASIC for KASPA and SEDRA (kHeavyHash) — Goldshell KA BOX and KA BOX Pro. These ASICs has high energy efficiency, low price and low noise, which makes them suitable for home use.
Kryptex Pool offers full support of Goldshell KA BOX ASIC, KA BOX Pro so you can expect exceptional efficiency and a consistent profit when mining KASPA and SEDRA.
Join us today:
Goldshell KA BOX, KA BOX Pro — Characteristics and Size
KA BOX kHeavyHash KASPA, SEDRA 1,18 Th/s (±5%) 400 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
KA BOX Pro kHeavyHash KASPA, SEDRA 1,6 Th/s (±5%) 600 Watt (±5%) 15 х 19,8 х 9,6 cm 2,2 kg
Goldshell KA BOX, KA BOX Pro Hashrate
Goldshell KA BOX ASIC can make 1,18 Th/s ±5% on kHeavyHash (KASPA) algorithm, which is equal to the hashrate of 12 Iceriver KS0, consuming 2 times less electricity — only 400 watts versus 780 watts. KA BOX Pro makes 1,6 Th/s ±5%
What to Mine on Goldshell KA BOX, KA BOX Pro?
Goldshell KA BOX, KA BOX Pro ASICs can only mine kHeavyHash algorithm: KASPA and SEDRA coins. You can’t reconfigure them to any other algorithms.
Goldshell KA BOX, KA BOX Pro Profitability
Check the profitability of Goldshell KA BOX Pro ASIC on the mining calculator.
Goldshell KA BOX, KA BOX Pro Settings
Coin URL Miner Name Password
kaspa:qzyjntttd55mpxdk54g6jryjwa46lgptwddtnqlxueg3val9j4z5c282f2elf.goldshell where
  • goldshell — Your ASIC name.
Goldshell KA BOX, KA BOX Pro Firmware Update
