How to mine QUAI SHA256
05.12.2025
QUAI SHA256 — a SHA256 algorithm fork of the QUAI coin within the QUAI SOAP project.
Quai is a high-throughput cryptocurrency. It runs on its own blockchain and processes over 50,000 transactions per second without compromising decentralization. The value of the project lies in fast and low-cost transactions. Its goal is to build a decentralized global payment system capable of handling massive transaction volumes.
SOAP (Subsidized Open-market Acquisition Protocol) is designed to ensure the resilience and security of the QUAI network. QUAI SOAP sells partner-chain tokens on the market and buys QUAI. Miners are rewarded in QUAI coins for their work.
⛏️ Mine QUAI SHA256 — https://pool.kryptex.com/quai-sha256
🔗 QUAI SHA256 Pool URLs:
- Global:
stratum+tcp://quai-sha256.kryptex.network:7044 - EU:
stratum+tcp://quai-sha256-eu.kryptex.network:7044 - US:
stratum+tcp://quai-sha256-us.kryptex.network:7044 - SG:
stratum+tcp://quai-sha256-sg.kryptex.network:7044 - RU:
stratum+tcp://quai-sha256-ru.kryptex.network:7044
Supported Miners
To mine QUAI SHA256, you need an SHA256 or SHA256Boost ASIC.
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Fluminer
- Bitdeer
- Ebang
- Bitaxe
- Aixin
This is only a partial list of ASIC manufacturers. Kryptex Pool supports any SHA256 ASIC miner.
QUAI can also be mined with Scrypt ASICs or GPUs using the QUAI ProgPow and QUAI KawPow algorithms.
Register a QUAI Wallet
To mine QUAI SHA256, you need to register a QUAI wallet address.
- Create a personal wallet address in Pelagus Wallet — https://pelaguswallet.io/
- A wallet address can also be obtained from exchanges: MEXC, Gate.io, CoinEX
👉 Detailed guide on how to register a QUAI wallet address.
We strongly recommend using only personal wallets for mining and long-term storage.
Connecting to the QUAI SHA256 Pool: Step-by-Step Guide
| Region | URL | Wallet Template | Password |
| Global | quai-sha256.kryptex.network:7044 |
wallet.worker |
x or leave blank |
| EU | quai-sha256-eu.kryptex.network:7044 |
wallet.worker |
x or leave blank |
| US | quai-sha256-us.kryptex.network:7044 |
wallet.worker |
x or leave blank |
| SG | quai-sha256-sg.kryptex.network:7044 |
wallet.worker |
x or leave blank |
| RU | quai-sha256-ru.kryptex.network:7044 |
wallet.worker |
x or leave blank |
Access the control panel of your ASIC.
Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
Input the following settings:
- URL of QUAI SHA256 mining pool:
stratum+tcp://quai-sha256.kryptex.network:7044 - Worker: Enter the wallet address for mining and the worker name in the format
0x002fb1466602cdca5b4b4010e64154443417bccd.S21where:0x002fb1466602cdca5b4b4010e64154443417bccd— represents the QUAI wallet address.S21is the chosen name for your worker in free form. - Password: This field is optional. You can either enter
xor leave it blank.
Replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
Save and apply the settings, then reboot the ASIC.
Open the QUAI SHA256 Kryptex Pool — https://pool.kryptex.com/quai-sha256
Payouts
Press the “Settings” button.
Press the “Submit” button.
