How To Mine eCash XEC
21.03.2025
eCash (XEC) is a cryptocurrency built on Bitcoin ABC, rebranded in 2021. It leverages the Avalanche protocol for fast and secure transactions, supports tokens and NFTs. Focused on scalability and user-friendliness, it’s ideal for DeFi and applications. Leading exchanges endorse the coin, and miners appreciate its high profitability.
Kryptex Pool supports mining eCash XEC using various SHA256 ASIC devices.
GPUs and CPUs, however, aren't capable of mining eCash XEC, as they simply lack the necessary processing power.
Supported miners
Kryptex eCash XEC Pool supports all well-known miner manufacturers:
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Aladdin
- Bitfury
- Ebang
- Aixin
Create An eCash XEC Wallet
To start eCash XEC mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
- Access the control panel of your ASIC.
- Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
- Input the following settings: - URL of the eCash XEC mining pool: stratum+tcp://xec.kryptex.network:7036
- Worker: Enter the wallet address for mining and the worker name in the format Wallet_Address.Worker_Name. The worker's name should comprise numbers and Latin letters, excluding spaces or special characters.
- For instance: ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9.Antminer_S21where:ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9— represents the eCash XEC wallet address.Antminer_S21is the chosen name for your worker in free form.
- Ensure you use a eCash XEC wallet address.
- Password: This field is optional. You can either enter xor leave it blank.
- If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
- Save and apply the settings, then reboot the ASIC.
- Visit the eCash XEC Kryptex Pool at https://pool.kryptex.com/xec.
- Input your wallet address into the search field and press Enter.
- View the statistics related to your ASIC on the pool.
- For additional monitoring, you can also track the performance of your ASIC through our dedicated monitoring bot on Telegram: https://t.me/KryptexMonitoringBot.
Payouts
- Open the eCash XEC pool page and enter your mining address;
- Press the “Settings” button.
- Set the desired “Payment Threshold”. Minimum and maximum payment threshold mentioned at the pool home page.
- In the "Ip Address" cell, enter the IP address of the worker whose name the site prompts you. The external IP address of your ASIC. The IP address must end the same as indicated in the prompt on the site (see the last digits). Learn your IP here https://ipinfo.io/ip
- Press the “Submit” button.
- Track the status of your payments in the "Payouts" tab.
- Email support at support@kryptex.com.
