How to mine Bitcoin BTC
17.02.2024
How To Mine Bitcoin BTC 👇
Bitcoin is the most renowned cryptocurrency, emerging in 2009 through the efforts of a mysterious individual or group using the pseudonym Satoshi Nakamoto. Employing blockchain technology, Bitcoin facilitates decentralized and secure transactions of digital assets. Throughout its existence, Bitcoin has evolved into the most expensive and precious cryptocurrency.
The Kryptex Pool supports Bitcoin mining with various ASICs. Graphics cards and processors lack the necessary computational power for Bitcoin mining.
Supported miners
Kryptex BTC Pool supports all well-known Bitcoin miner manufacturers:
- Bitmain Antminer
 - Whatsminer MicroBT
 - Canaan Avalon
 - Innosilicon
 - Aladdin
 - Bitfury
 - Ebang
 - Aixin
Create a Bitcoin Wallet
To start Bitcoin mining, you should have a Bitcoin wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
For prolonged BTC storage, we recommend using your own wallets.
- Access the control panel of your ASIC.
 - Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
 - Input the following settings:
- URL of the BTC mining pool:
stratum+tcp://btc.kryptex.network:7014 - Worker: Enter the wallet address for mining and the worker name in the format
1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE.Antminer_S9Dwhere:
1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE— represents the Bitcoin wallet address.
Antminer_S9Dis the chosen name for your worker in free form. - Ensure you use a Legacy, P2SH, or SegWit Bitcoin wallet address.
 - Password: This field is optional. You can either enter
xor leave it blank.
 - If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
 - Save and apply the settings, then reboot the ASIC.
Visit the BTC Kryptex Pool at https://pool.kryptex.com/btc.
Payouts
Press the “Settings” button.
Press the “Submit” button.
