Conexão
How to mine Bitcoin BTC
11/05/2026
Check our YouTube Video how to mine Bitcoin BTC
Bitcoin is the most renowned cryptocurrency, emerging in 2009 through the efforts of a mysterious individual or group using the pseudonym Satoshi Nakamoto. Employing blockchain technology, Bitcoin facilitates decentralized and secure transactions of digital assets. Throughout its existence, Bitcoin has evolved into the most expensive and precious cryptocurrency.
The Kryptex Pool supports Bitcoin mining with various ASICs. Graphics cards and processors lack the necessary computational power for Bitcoin mining.
Supported miners
Kryptex BTC Pool supports all well-known Bitcoin miner manufacturers:
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Aladdin
  • Bitfury
  • Ebang
  • Aixin
Create a Bitcoin Wallet
To start Bitcoin mining, you should have a Bitcoin wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
For prolonged BTC storage, we recommend using your own wallets.
    • URL of the BTC mining pool: stratum+tcp://btc.kryptex.network:7014
    • For instance: 1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE.Antminer_S9D where:
      1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE — represents the Bitcoin wallet address.
      Antminer_S9D is the chosen name for your worker in free form.
    • Ensure you use a Legacy, P2SH, or SegWit Bitcoin wallet address.
  1. Visit the BTC Kryptex Pool at https://pool.kryptex.com/btc.
Payouts
  5. Press the “Submit” button.
