ASIC iBeLink BM-KS Max
13.05.2026
iBeLink has introduced the most powerful ASIC miner for KASPA and SEDRA (kHeavyHash) — iBeLink BM-KS Max. This ASIC outperforms the most powerful rivals by 15-20%.
Kryprex Pool offers full support of iBeLink BM-KS Max ASIC, so you can expect exceptional efficiency and a consistent profit when mining KASPA and SEDRA.
Join us today:
iBeLink BM-KS Max — Characteristics and Size
Manufacturer — iBeLink
Model — BM-KS Max
Algorithm — kHeavyHash
Coins — KASPA, SEDRA
Hashrate — 10,5 Th/s ±5%
Power Consumption — 3400 Watt ±3%
Dimensions — 34 х 19 х 29,3 cm
Weight — 12,2 kg
iBeLink BM-KS Max Hashrate
iBeLink BM-KS Max ASICs’ can make 10,5 Th/s ±5% on kHeavyHash (KASPA) algorithm, which is equal to the hashrate of 105 Iceriver KS0, consuming 2 times less electricity — only 3400 watts versus 6825 watts.
What to Mine on iBeLink BM-KS Max?
iBeLink BM-KS Max can only mine kHeavyHash algorithm: KASPA and SEDRA coins. You can’t reconfigure them to any other algorithms.
iBeLink BM-KS Max Profitability
Check the profitability of iBeLink BM-KS Max ASICs on the mining calculator.
iBeLink BM-KS Max Settings
Go to “Settings → Pool Setting” tab to setup your ASIC.
| Coin | Pool URL | Worker | Password |
x or leave blank |
x or leave blank |
Worker — The wallet address and worker name specified like this:
kaspa:qzyjntttd55mpxdk54g6jryjwa46lgptwddtnqlxueg3val9j4z5c282f2elf.ibelink where
kaspa:qzyjntttd55mpxdk54g6jryjwa46lgptwddtnqlxueg3val9j4z5c282f2elf— your wallet address, starting withkaspa:ibelink— Your ASIC name.
Monitor your ASIC’s work on the “Status” page. Here you will see your hashrate, statistics of accepted shares and all related information.
iBeLink BM-KS Max Firmware Update
Go to the manufacturer's website and download the required firmware: https://en.ibelink.com.hk/xiazai/
Open the page for updating “Upgrade”, select the downloaded update.
