19.05.2026
Goldshell has introduced the world's first ALPH (Blake3) mining ASICs — Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III. These ASICs has high energy efficiency, high income and low noise, which makes them suitable for home use.
Kryptex Pool offers full support of Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III so you can expect exceptional efficiency and a consistent profit when mining ALPH.
Join us today at https://pool.kryptex.com/alph
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III — Characteristics and Size
| AL BOX | Blake3 | ALPH | 360 GH/s (±5%) | 180 Watt (±5%) | 15 х 19,8 х 9,6 cm | 2,2 kg |
| AL BOX II | Blake3 | ALPH | 720 GH/s (±5%) | 360 Watt (±5%) | 15 х 19,8 х 9,6 cm | 2,2 kg |
| AL BOX II PLUS | Blake3 | ALPH | 1 TH/s (±5%) | 480 Watt (±5%) | 15 х 19,8 х 9,6 cm | 2,2 kg |
| AL BOX III | Blake3 | ALPH | 1,25 TH/s (±5%) | 600 Watt (±5%) | 15 х 19,8 х 9,6 cm | 2,2 kg |
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Hashrate
Goldshell AL BOX ASICs’ can make 360 Gh/s ±5% on Blake3 (ALPH) algorithm, which is equal to the hashrate of 60 RTX 4090, consuming 93 times less electricity — only 180 watts versus 16800 watts.
Model AL BOX III triples the result — 1,25 TH/s (±5%) with a consumption of only 600 Watts.
What to Mine on Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III?
Goldshell AL BOX, AL BOX II, AL BOX III ASICs can mine coins using Blake3 algorithm. You can’t reconfigure them for any other algorithms.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Profitability
Check the profitability of Goldshell AL BOX III ASIC on the mining calculator.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Settings
| Coin | URL | Miner Name | Password |
x or leave blank |
1B7fgnoznDCoRJQBZqKLU2DBBfRBUEPNeBCpWFLTctwmK.goldshell where
1B7fgnoznDCoRJQBZqKLU2DBBfRBUEPNeBCpWFLTctwmK— your wallet address,goldshell— Your ASIC name.
Goldshell AL BOX, AL BOX II, AL BOX II PLUS, AL BOX III Firmware Update
Go to the manufacturer's Github and download the required firmware: https://github.com/goldshellminer/firmware
Open the page for updating “System → Update”, select the downloaded update.
