Połączenie
How to mine QUAI SHA256
15.09.2026
Check our YouTube Video how to mine QUAI SHA256
QUAI SHA256 — a SHA256 algorithm fork of the QUAI coin within the QUAI SOAP project.
Quai is a high-throughput cryptocurrency. It runs on its own blockchain and processes over 50,000 transactions per second without compromising decentralization. The value of the project lies in fast and low-cost transactions. Its goal is to build a decentralized global payment system capable of handling massive transaction volumes.
SOAP (Subsidized Open-market Acquisition Protocol) is designed to ensure the resilience and security of the QUAI network. QUAI SOAP sells partner-chain tokens on the market and buys QUAI. Miners are rewarded in QUAI coins for their work.
⛏️ Mine QUAI SHA256 — https://pool.kryptex.com/quai-sha256
🔗 QUAI SHA256 Pool URLs:
  • Global: stratum+tcp://quai-sha256.kryptex.network:7044
  • EU: stratum+tcp://quai-sha256-eu.kryptex.network:7044
  • US: stratum+tcp://quai-sha256-us.kryptex.network:7044
  • SG: stratum+tcp://quai-sha256-sg.kryptex.network:7044
  • RU: stratum+tcp://quai-sha256-ru.kryptex.network:7044
Supported Miners
To mine QUAI SHA256, you need an SHA256 or SHA256Boost ASIC.
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Fluminer
  • Bitdeer
  • Ebang
  • Bitaxe
  • Aixin
This is only a partial list of ASIC manufacturers. Kryptex Pool supports any SHA256 ASIC miner.
QUAI can also be mined with Scrypt ASICs or GPUs using the QUAI ProgPow and QUAI KawPow algorithms.
Register a QUAI Wallet
To mine QUAI SHA256, you need to register a QUAI wallet address.
👉 Detailed guide on how to register a QUAI wallet address.
We strongly recommend using only personal wallets for mining and long-term storage.
Connecting to the QUAI SHA256 Pool: Step-by-Step Guide
Region URL Wallet Template Password
Global quai-sha256.kryptex.network:7044 wallet.worker x or leave blank
EU quai-sha256-eu.kryptex.network:7044 wallet.worker x or leave blank
US quai-sha256-us.kryptex.network:7044 wallet.worker x or leave blank
SG quai-sha256-sg.kryptex.network:7044 wallet.worker x or leave blank
RU quai-sha256-ru.kryptex.network:7044 wallet.worker x or leave blank
    • URL of QUAI SHA256 mining pool: stratum+tcp://quai-sha256.kryptex.network:7044
    • For instance: 0x002fb1466602cdca5b4b4010e64154443417bccd.S21 where: 0x002fb1466602cdca5b4b4010e64154443417bccd — represents the QUAI wallet address. S21 is the chosen name for your worker in free form.
  4. Replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
  1. Open the QUAI SHA256 Kryptex Pool — https://pool.kryptex.com/quai-sha256
Payouts
  5. Press the “Submit” button.
