ASIC Antminer E9 Pro
26.11.2026
Bitmain has released an updated version of the ASIC Antminer E9 — Antminer E9 Pro. Kryptex PPS+ Pool is the best and almost the only pool that has tested and supports Bitmain Antminer E9 Pro ASIC.
Antminer E9 Pro — Characteristics and Size
Manufacturer — Bitmain
Model — Antminer E9 Pro
Algorithm — Ethash, Etchash
Coins — Ethereum Classic (ETC), OctaSpace (OCTA)
Hashrate ~ 3680 Mh/s
Power Consumption — 2000-2200 Watt
Dimensions — 57 х 31,5 х 43 cm
Weight ~ 19 kg
Antminer E9 Pro Hashrate
Antminer E9 Pro ASIC hashrate ~ 3680 Mh/s on the Etchash (ETC) and Ethash (OCTA) algorithms, which is equal to the hashrate of 30 graphics cards Nvidia RTX 3080 Ti, consuming 4 times less — only 2200 watts versus 9600 watts. As in the case with graphics cards, there is a luck factor — some ASICs can be overclocked up to 4000 Mh/s.
Antminer E9 Pro is almost the most powerful ASIC for ETC and OCTA coins that can be mined on Kryptex PPS Pool.
What to Mine on Antminer E9 Pro?
Antminer E9 Pro mines the Etchash and Ethash algorithms, so it suits Ethereum Classic (ETC) and OctaSpace (OCTA).
Antminer E9 Pro can no longer mine Ethereum PoW (ETHW): the ASIC doesn't have enough memory for this coin, and the pool rejects all its shares.
Antminer E9 Pro Profitability
Currently, the profitability of Antminer E9 Pro ASIC varies from 6$/day up to 20 $/day, depending on the mining coin, and excluding electricity costs.
Check the profitability of ASIC Antminer E9 Pro on the mining calculator.
Antminer E9 Pro Settings
Initially, Antminer E9 Pro comes with firmware for Ethereum Classic (ETC). To mine OctaSpace (OCTA), you will need to change the firmware.
Go to “Settings” tab setup your ASIC.
| Coin | Mining Address | Miner Name | Password |
| ETC | etc.kryptex.network:7033 or stratum+tcp://etc.kryptex.network:7033 |
leave blank |
| OCTA | octa.kryptex.network:7032 or stratum+tcp://octa.kryptex.network:7032 |
leave blank |
0x3BF96862802EFe07B51c4E18D8232d8439aec373.e9pro where
0x3BF96862802EFe07B51c4E18D8232d8439aec373— your wallet address;e9pro— Your ASIC name.
After restarting, the ASIC takes up to 15 minutes to connect to the pool.
Antminer E9 Pro Firmware Update
Initially, ASIC Antminer E9 Pro comes with firmware that allows you to mine Ethereum Classic (ETC). To mine OctaSpace (OCTA), you will need to change the firmware.
You can update or change the firmware yourself, for this:
Go to the manufacturer's website and download the required firmware: https://shop.bitmain.com/support/download
Open the page for updating “Firmware Update”, select the downloaded update.
