13.05.2026
Elphapex has released their latest generation of Scrypt ASICs.
These models offer varying levels of performance and efficiency, allowing you to choose the best option based on your needs and budget.
- The Elphapex DG1 and DG1+ have already received positive reviews for their high performance and efficiency.
- The Elphapex DG Hydro 1 is Elphapex's most powerful Scrypt ASIC with water cooling.
- The Elphapex DG Home 1 is the first quiet, home ASIC. Its compact form factor, silent operation, and low power consumption make it suitable for installation even in an apartment.
Kryptex PPS+ Pool is the best pool that has tested and supports the new Elphapex DG1, DG1+, DG Hydro 1, and DG Home 1 ASICs.
On the Kryptex Pool, Elphapex Scrypt ASICs can mine multiple coins simultaneously! With merged mining, you can mine Litecoin and Dogecoin, Pepecoin, and Bells together.
Start mining LTC+DOGE+PEP+BELLS — https://pool.kryptex.com/ltc
Elphapex DG1, DG1+, DG Hydro 1, DG Home 1 — Specifications and Size
| DG Hydro 1 | Scrypt | LTC, DOGE, PEP, BELLS | 20 Gh/s (±10%) | 6200 Watt (±10%) | 76 x 59 x 24,5 | 25 kg |
| DG 1 + | Scrypt | LTC, DOGE, PEP, BELLS | 14 Gh/s (±10%) | 3920 Watt (±10%) | 43,3 x 28,7 x 19,6 | 18,3 kg |
| DG 1 | Scrypt | LTC, DOGE, PEP, BELLS | 11 Gh/s (±10%) | 3420 Watt (±10%) | 43,3 x 28,7 x 19,6 | 18,3 kg |
| DG Home 1 | Scrypt | LTC, DOGE, PEP, BELLS | 2,1 Gh/s (±10%) | 630 Watt (±10%) | 41 x 37 x 13,5 | 10,3 kg |
Elphapex DG1, DG1+, DG Hydro 1, DG Home 1 Hashrate
The hash rate of the Elphapex ASICs DG1, DG1+, DG Hydro 1, and DG Home 1 ranges from 2.1 Gh/s to 20 Gh/s, depending on the model.
The entry-level model, Elphapex DG Home 1, designed to be a quiet ASIC for apartments, delivers a hash rate of 2.1 Gh/s on the Scrypt algorithm.
DG Hydro 1, the most powerful Elphapex ASIC for coins like LTC, DOGE, PEP, and BELLS using the Scrypt algorithm, provides a hash rate of 20 Gh/s.
What to Mine on** Elphapex DG1, DG1+, DG Hydro 1, DG Home 1?
The Elphapex DG1, DG1+, DG Hydro 1, and DG Home 1 ASICs can mine coins using the Scrypt algorithm.
The Scrypt algorithm allows for multiple coin mining simultaneously, known as merge-mining. With merge-mining, you can mine Litecoin, Dogecoin, Pepecoin, and Bells together.
On the Kryptex Pool, Elphapex Scrypt ASICs can mine multiple coins at the same time!
Elphapex DG1, DG1+, DG Hydro 1, DG Home 1 Profitability
| DG Hydro 1 | 20 Gh/s (±10%) | 6200 Watt (±10%) |
| DG 1 + | 14 Gh/s (±10%) | 3920 Watt (±10%) |
| DG 1 | 11 Gh/s (±10%) | 3420 Watt (±10%) |
| DG Home 1 | 2,1 Gh/s (±10%) | 630 Watt (±10%) |
Check the profitability of Elphapex DG1 ASIC on the mining calculator.
Elphapex DG1, DG1+, DG Hydro 1, DG Home 1 Settings
Go to “Mining” tab to setup your ASIC.
| Coin | Mining Address | User Name | Password |
| LTC+DOGE+PEP+BELLS | stratum+tcp://ltc.kryptex.network:7016 or stratum+tcp://ltc-eu.kryptex.network:7016 |
LTC_WALLET_ADDRESS.WORKER_NAME |
x or leave blank |
User Name — The wallet address and worker name specified like this:
LgETtY86dfiWsgD3Mmcx1PtzhCdeYUVBaL.01 where
LgETtY86dfiWsgD3Mmcx1PtzhCdeYUVBaL— your wallet address;01— Your ASIC name.
Fill in all three lines with the same settings, as shown in the screenshot above, to ensure the ASIC resumes operation in case of a connection interruption.
Click “Save” to save the settings and then “Reboot” to apply settings and start mining.
Elphapex DG1, DG1+, DG Hydro 1, DG Home 1 Firmware Update
- Go to the manufacturer's website and download the required firmware: https://www.elphapex.com/support/download?type=Firmware
- Open the page for updating “Update”, select the downloaded update.
- Update and reboot your ASIC according to the developer's instructions.
