How to mine Ethereum Classic (ETC)
10.06.2024
For Ethereum Classic mining you need ASIC, mining on graphics cards will be useless due to the high difficulty of the network.
Here is a complete list of ASIC models for Ethereum Classic (ETC) mining.
For ETC mining, an Ethash-ASIC with at least 4GB of memory is required.
Step one — register a wallet
  1. Register the wallet https://metamask.io/.
    Detailed instruction on How to create Ethereum Classic (ETC) wallet.
  2. You can trade Ethereum Classic (ETC) with on of the following exchangers: Binance, Gate.io, MEXC, CoinEx, KuCoin, ByBit.
We recommend you mine to your wallet and then transfer the cryptocurrency to the exchange. That will be more reliable.
Step two — setup your ASIC
Quick-start mining settings
Ethereum Classic Pool — https://pool.kryptex.com/etc
Pool address: stratum+tcp://etc.kryptex.network:7033
  1. Open Ethereum Classic pool page https://pool.kryptex.com/etc
Step Four — payout
  5. Press the “Submit” button.
🤯Too complicated?
