Підключення
How to mine Bitcoin Cash BCH
19.05.2026
Check our YouTube Video how to mine Bitcoin Cash BCH
Bitcoin Cash is a cryptocurrency that emerged in 2017 as a result of a Bitcoin hard fork. It was created to address scalability issues, offering faster transactions and lower fees by increasing the block size. Over time, Bitcoin Cash has become a popular alternative for those looking for more affordable and quicker cryptocurrency transactions.
Kryptex Pool supports mining Bitcoin Cash using various SHA256 ASIC devices.
GPUs and CPUs, however, aren't capable of mining Bitcoin Cash, as they simply lack the necessary processing power.
Supported miners
Kryptex BCH Pool supports all well-known miner manufacturers:
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Aladdin
  • Bitfury
  • Ebang
  • Aixin
Create a Bitcoin Cash BCH Wallet
To start Bitcoin Cash mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
    • URL of the BCH mining pool: stratum+tcp://bch.kryptex.network:7015
    • For instance: 1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE.Antminer_S9D where: 1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE — represents the Bitcoin Cash wallet address. Antminer_S9D is the chosen name for your worker in free form.
    • Ensure you use wallet format Bitcoin Cash Legacy (1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE) or CashAddr (bitcoincash:qpm2qsznhks23z7629mms6s4cwef74vcwvy22gdx6a).
  1. Visit the BCH Kryptex Pool at https://pool.kryptex.com/bch.
Payouts
  1. Open the BCH pool page and enter your mining address;
  5. Press the “Submit” button.
