اصطلاحات
Uncle Block (Ommer)
16/4/2026
Uncle block (also called ommer) was a valid block produced on the Ethereum network that wasn't included in the main chain, but was referenced by a canonical block and earned its miner a partial reward. Uncles existed only during Ethereum's Proof-of-Work era — they were eliminated by The Merge in September 2022.
How uncles worked
When two miners found a valid Ethereum block at the same height, only one could extend the main chain — the other became an uncle. Because Ethereum's block time was ~13 seconds (much shorter than Bitcoin's ~10 minutes), such collisions were common; without compensation, poorly-connected miners would be systematically disadvantaged.
The GHOST protocol (Greedy Heaviest Observed Subtree) solved this by allowing canonical blocks to reference recent uncles:
  • The canonical block miner received a small bonus for including an uncle reference
  • The uncle miner received a partial block reward (around 1.75 ETH before The Merge)
  • Up to 2 uncles could be included per block
  • Only uncles within 6 generations of the referencing block qualified
Transactions in the uncle block did not execute on the main chain — only the block header was acknowledged.
Uncle vs orphan
Uncle Orphan
Valid PoW? Yes Yes
Parent in main chain? Yes Yes (for orphans in most chains)
Referenced by main chain? Yes No
Reward? Partial None
In everyday language, uncles were Ethereum-specific; Bitcoin and most other chains have only orphan/stale blocks with no reward.
After The Merge
Proof-of-Stake replaced competitive mining with a single randomly-assigned block proposer per slot. Two validators can't produce competing blocks at the same height, so uncles no longer exist on Ethereum — post-Merge blocks always contain an empty ommer list.
See also
