کنکشن
30/3/2026
Bitmain has introduced 2 new ASICs for KASPA and SEDRA (kHeavyHash) — Antminer KS5 and Antminer KS5 Pro. These ASICs are about 2 times more powerful than the earlier models, which makes them currently the most profitable ASICs in the world!
We offer full support of Antminer KS5, KS5 Pro ASICs, so you can expect exceptional efficiency and a consistent profit when mining KASPA and SEDRA.
Join us today:
Antminer KS5, KS5 Pro — Characteristics and Size
KS5 kHeavyHash KASPA, SEDRA 20 TH/s (±3%) 3000 Watt (±5%) 43 x 19,5 x 29 cm 15,8 kg
KS5 Pro kHeavyHash KASPA, SEDRA 21 TH/s (±3%) 3150 Watt (±5%) 43 x 19,5 x 29 cm 15,8 kg
Antminer KS5, KS5 Pro Hashrate
Antminer KS5 ASICs’ can make 20 Th/s (±3%) on kHeavyHash (KASPA) algorithm, which is equal to the hashrate of 200 Iceriver KS0, consuming 4,5 times less electricity — only 3000 watts versus 13000 watts.
The higher KS5 Pro model has a hashrate of 21 Th/s (±3%) and consumes 3150W, making the KS5 Pro the most powerful kHeavyHash ASIC in the world.
What to Mine on Antminer KS5, KS5 Pro?
Bitmain Antminer KS5 and KS5 Pro ASICs can only mine kHeavyHash algorithm: KASPA and SEDRA coins. You can’t reconfigure them to any other algorithms.
Antminer KS5, KS5 Pro Profitability
Currently, the daily profitability of Bitmain Antminer KS5 is about ~ 72$, excluding electricity costs. The Pro version has a daily profitability of about 76$.
Check the profitability of Antminer KS5 ASICs on the mining calculator.
Antminer KS5, KS5 Pro Settings
Go to “Settings” tab to setup your ASIC.
Coin Mining Address Miner Name Password
kaspa:qzyjntttd55mpxdk54g6jryjwa46lgptwddtnqlxueg3val9j4z5c282f2elf.bitmain where
  • bitmain — Your ASIC name.
Antminer KS5, KS5 Pro Firmware Update
  1. Go to the manufacturer's website and download the required firmware: https://shop.bitmain.com/support/download
  2. Open the page for updating “Firmware upgrade”, select the downloaded update.
