Connessione
How to mine Litecoin LTC with Dogecoin DOGE
11/05/2026
Check our YouTube Video how to mine Litecoin LTC
Litecoin is a cryptocurrency created in 2011 by Charlie Lee, a former Google employee. It was designed as a "lighter" version of Bitcoin, offering faster transactions and lower fees. Over time, Litecoin has become one of the most popular and well-established cryptocurrencies, widely used for quick and inexpensive transfers.
Dogecoin, on the other hand, was created in 2013 by programmers Billy Markus and Jackson Palmer as a joke, based on the popular Shiba Inu dog meme. Despite its humorous origins, Dogecoin gained a large community and is commonly used for tipping online and charitable donations. Over the years, it has become one of the most recognizable cryptocurrencies, thanks in part to the support of its user base and public figures.
Kryptex Pool supports mining Litecoin along with Dogecoin using various ASIC devices. GPUs and CPUs, however, aren't capable of mining Litecoin, as they simply lack the necessary processing power.
With merge mining, you mine Litecoin and Dogecoin together. Every 24 hours, we convert Dogecoin to Litecoin, adding a bonus to your Litecoin rewards.
Supported miners
Kryptex LTC+DOGE Pool supports all well-known miner manufacturers:
  • Bitmain Antminer
  • Goldshell
  • ElphaPex
  • Innosilicon
  • FusionSilicon
  • BW
Create a Litecoin LTC Wallet
To start Litecoin + Dogecoin mining, you should have a Litecoin wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
Let's take the Bitmain Antminer L9 ASIC as an example.
    • URL of the LTC+DOGE mining pool: stratum+tcp://ltc.kryptex.network:7016
    • For instance: LgETtY86dfiWsgD3Mmcx1PtzhCdeYUVBaL.L9 where: LgETtY86dfiWsgD3Mmcx1PtzhCdeYUVBaL — represents the Litecoin wallet address. L9 is the chosen name for your worker in free form.
    • Ensure you use a Legacy Litecoin or SegWit Litecoin wallet address.
  1. Visit the LTC+DOGE Kryptex Pool at https://pool.kryptex.com/ltc.
Payouts
  1. Open the LTC+DOGE pool page and enter your mining address;
  5. Press the “Submit” button.
