How to mine Bitcoin Cash BCH
30/03/2026
Bitcoin Cash is a cryptocurrency that emerged in 2017 as a result of a Bitcoin hard fork. It was created to address scalability issues, offering faster transactions and lower fees by increasing the block size. Over time, Bitcoin Cash has become a popular alternative for those looking for more affordable and quicker cryptocurrency transactions.
Kryptex Pool supports mining Bitcoin Cash using various SHA256 ASIC devices.
GPUs and CPUs, however, aren't capable of mining Bitcoin Cash, as they simply lack the necessary processing power.
Supported miners
Kryptex BCH Pool supports all well-known miner manufacturers:
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Aladdin
- Bitfury
- Ebang
- Aixin
Create a Bitcoin Cash BCH Wallet
To start Bitcoin Cash mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
- Access the control panel of your ASIC.
- Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
- Input the following settings:
- URL of the BCH mining pool:
stratum+tcp://bch.kryptex.network:7015 - Worker: Enter the wallet address for mining and the worker name in the format
1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE.Antminer_S9Dwhere:1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE— represents the Bitcoin Cash wallet address.Antminer_S9Dis the chosen name for your worker in free form. - Ensure you use wallet format Bitcoin Cash Legacy (
1KVms9T3RKmz6sVCeUPFPFgpYzMj9LZ5rE) or CashAddr (bitcoincash:qpm2qsznhks23z7629mms6s4cwef74vcwvy22gdx6a). - Password: This field is optional. You can either enter
xor leave it blank.
- If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
- Save and apply the settings, then reboot the ASIC.
Visit the BCH Kryptex Pool at https://pool.kryptex.com/bch.
Payouts
Open the BCH pool page and enter your mining address;
Press the “Settings” button.
Press the “Submit” button.
