Connessione
How to mine Fractal Bitcoin FB
11/05/2026
Check our YouTube Video how to mine Fractal Bitcoin FB
Fractal Bitcoin is a cryptocurrency designed to enhance transaction anonymity and security compared to traditional Bitcoin. By leveraging an advanced blockchain structure, Fractal Bitcoin focuses on privacy and decentralization. Over time, the project has gained attention from those seeking more private methods for exchanging digital assets.
Kryptex Pool supports mining Fractal Bitcoin using various SHA256 ASIC devices. GPUs and CPUs, however, aren't capable of mining Fractal Bitcoin, as they simply lack the necessary processing power.
Supported miners
Kryptex FB Pool supports all well-known miner manufacturers:
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Aladdin
  • Bitfury
  • Ebang
  • Aixin
Create a Fractal Bitcoin FB Wallet
To start Fractal Bitcoin mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
    • URL of the FB mining pool: stratum+tcp://fb.kryptex.network:7013
    • For instance: 1JnCDKc1tnKSkj1CMhegTxS3kRpsw5msWv.Antminer_S9D where: 1JnCDKc1tnKSkj1CMhegTxS3kRpsw5msWv — represents the Fractal Bitcoin wallet address. Antminer_S9D is the chosen name for your worker in free form.
    • Ensure you use a Fractal Bitcoin wallet address.
  1. Visit the FB Kryptex Pool at https://pool.kryptex.com/fb.
Payouts
  1. Open the FB pool page and enter your mining address;
  5. Press the “Submit” button.
