Connessione
ASIC Goldshell E-AL1M
13/05/2026
Goldshell has introduced a new ASIC for Alephium ALPH (Blake3) — Goldshell E-AL1M. The ASIC turned out to be relatively cheap and energy efficient. The ASIC has two operating modes: 4.4 Th/s 1800 Watt and 3.0 Th/s 1100 Watt.
Kryptex Pool offers full support of Goldshell E-AL1M so you can expect exceptional efficiency and a consistent profit when mining Alephium ALPH (Blake3).
Join us today — https://pool.kryptex.com/alph
Goldshell E-AL1M — Characteristics and Size
Model Algorithm Coin Hashrate Consumption Dimensions Weight
E-AL1M Blake3-Alephium ALPH 4,4 Th/s (±5%) 1800 Watt (±5%) 44,3 х 36 х 13,5 cm 16 kg
Goldshell E-AL1M Hashrate
The hashrate of the Goldshell E-AL1M ASIC at a maximum power of 1800 watts is 4.4 Th/s ±5% on the Blake3-Alephium (ALPH) algorithm. In the reduced power mode of 1100 watts, the Goldshell E-AL1M ASIC produces a hashrate of 3.0 Th/s ±5%.
What to Mine on Goldshell E-AL1M?
ASIC Goldshell E-AL1M can only mine Blake3-Alephium algorithm: ALPH coin. You can’t reconfigure it to mine any other algorithms.
Goldshell E-AL1M Profitability
Check the profitability of Goldshell E-AL1M ASIC on the mining calculator.
Goldshell E-AL1M Settings
Coin URL Miner Name Password
ALPH stratum+tcp://alph.kryptex.network:7010 ALPH_WALLET_ADDRESS.WORKER_NAME x or leave blank
1BFYPwvcZxgU9ZmJTvsLkj8cqrgaLB6mqgfJGZY6toFH9.goldshell where
  • 1BFYPwvcZxgU9ZmJTvsLkj8cqrgaLB6mqgfJGZY6toFH9 — your wallet address,
  • goldshell — Your ASIC name.
Goldshell E-AL1M Firmware Update
