How to mine QUAI KawPow
2025/12/5
QUAI KawPow — a KawPow algorithm fork of the QUAI coin within the QUAI SOAP project.
Quai is a high-throughput cryptocurrency. It runs on its own blockchain and processes over 50,000 transactions per second without compromising decentralization. The value of the project lies in fast and low-cost transactions. Its goal is to build a decentralized global payment system capable of handling massive transaction volumes.
SOAP (Subsidized Open-market Acquisition Protocol) is designed to ensure the resilience and security of the QUAI network. QUAI SOAP sells partner-chain tokens on the market and buys QUAI. Miners are rewarded in QUAI coins for their work.
Supported Miners
To mine QUAI KawPow, you need a modern Nvidia, AMD, or Intel ARC GPU released no earlier than 2016. A minimum of 8 GB of memory is recommended. Older GPUs or those with less memory may not work.
KawPow is sensitive to core, memory, and power limit overclocking.
  • The higher the Power Limit, Core Clock, and Memory Clock, the higher the hashrate on QUAI KawPow.
  • KawPow runs hot, so overclock your GPUs carefully.
QUAI can also be mined with Scrypt ASICs, SHA256 ASICs, or GPUs using the QUAI ProgPow algorithm.
Register a QUAI Wallet
To mine QUAI KawPow, you need to register a QUAI wallet address.
👉 Detailed guide on how to register a QUAI wallet address.
We strongly recommend using only personal wallets for mining and long-term storage.
Quick-start mining settings
⛏️ Mine QUAI KawPow — https://pool.kryptex.com/quai-kawpow
🔗 QUAI KawPow Pool URLs:
  • Global: stratum+tcp://quai-kawpow.kryptex.network:7043
  • EU: stratum+tcp://quai-kawpow-eu.kryptex.network:7043
  • US: stratum+tcp://quai-kawpow-us.kryptex.network:7043
  • SG: stratum+tcp://quai-kawpow-sg.kryptex.network:7043
  • RU: stratum+tcp://quai-kawpow-ru.kryptex.network:7043
Connecting to the QUAI KawPow Pool: Step-by-Step Guide
If you are an experienced miner, you can skip this part of the guide. But if you are a beginner and have never set up mining on your own — this guide is for you! Keep reading:
  1. Download a miner for Quai KawPow. We recommend SRBMiner for AMD and Intel ARC и Rigel for NVIDIA. We will use Rigel as an example.
    • Antivirus programs don’t like miners. During the download, your antivirus or firewall may warn you of a potential threat — they are being cautious because they can’t tell whether you’re intentionally downloading mining software or not. Allow the file to download, or temporarily pause your antivirus while the file is being downloaded.
    • Right Mouse Click rigel.exe file
    • Choose “Properties
    • Choose “Compatibility” tab
    • Tick “Run this program as an administrator
    • Press “Apply” and “OK
  5. Open the Quai Network (QUAI) pool page — https://pool.kryptex.com/quai-kawpow
    • In the “Wallet address” field, enter the wallet address that you registered for earlier. Wallet address example: 0x002fb1466602cdca5b4b4010e64154443417bccd
    • In the “Worker name” cell, enter the name of the mining rig that will mine on the pool, for example, MyFirstRig. Please note that the name is entered only in Latin letters or numbers, without spaces.
  6. In the folder with the miner, create a plain text document .txt with the Notepad application. Let's call it Kryptex QUAI KawPow. Then, open the file, and paste the copied sample BAT file into the document. Or you can download a ready-made .bat file from the pool’s page and skip this step
  1. Open the Quai KawPow pool page — https://pool.kryptex.com/quai-kawpow
Payouts
  5. Press the “Submit” button.
