Đào coin
Pearl Miners Overview
18/6/2026
⛏️ Pearl (PRL) is mined on modern GPUs — Nvidia RTX 2000-series and newer, AMD RX 6000-series (RDNA2), and Intel Arc — using the pearlhash algorithm. This overview covers the GPU miners for Pearl and the ready commands to connect them to Kryptex Pool.
👉 Mine Pearl on Kryptex Pool: ready miner configs, HiveOS templates, 1% fee.
GPU mining Pearl (PRL) on the pearlhash algorithm
Pearl pool stratum addresses
Connect to the server closest to you — the lower the ping, the faster your shares reach the pool and the fewer stale or rejected shares you get. Multiple server regions also help when mining is restricted in your area: if one endpoint is blocked or unreachable, switch to another and keep mining.
Region Stratum address
Global prl.kryptex.network:7048
Europe prl-eu.kryptex.network:7048
North America prl-us.kryptex.network:7048
South America prl-br.kryptex.network:7048
Singapore prl-sg.kryptex.network:7048
Hong Kong prl-hk.kryptex.network:7048
Russia prl-ru.kryptex.network:7048
Middle East prl-ae.kryptex.network:7048
For SSL, use port 8048 on the same hosts.
In the commands below, replace WALLET_ADDRESS / WORKER_NAME with your PRL wallet and worker. For auto-exchange to BTC, use your Kryptex Mining Username instead of the wallet; for SOLO, add the solo: prefix.
WildRig setup for PRL
WildRig Multi is a popular multi-algorithm GPU miner. For Pearl on Kryptex Pool we recommend SRBMiner-MULTI or BzMiner instead — these are the miners we support, and they cover Nvidia, AMD and Intel Arc. If you came looking for a WildRig PRL setup, use one of the configs below.
SRBMiner-MULTI is the recommended Pearl miner
SRBMiner setup for PRL
SRBMiner-MULTI (Windows and Linux) mines Pearl on the pearlhash algorithm and supports Nvidia and AMD RX 6000-series (RDNA2) cards.
SRBMiner-MULTI.exe --disable-cpu --algorithm pearlhash --pool prl.kryptex.network:7048 --wallet WALLET_ADDRESS.WORKER_NAME
BzMiner setup for PRL
BzMiner runs on Nvidia, AMD and Intel Arc:
bzminer -a pearl -p stratum+tcp://prl.kryptex.network:7048 -w WALLET_ADDRESS/WORKER_NAME --nvidia 1 --amd 1 --intel 1 --igpu 0 --cpu 0 --cpu_threads 0 --nc 1
On Linux, run the same command as ./bzminer.
PeakMiner setup for PRL
PeakMiner (Nvidia) picks TCP or SSL automatically by the port:
peakminer --coin pearl -o prl.kryptex.network:7048 -u WALLET_ADDRESS/WORKER_NAME
On Linux, run it as ./peakminer.
ARCMiner setup for PRL
ARCMiner is built for Intel Arc GPUs:
arc-miner.exe --pool stratum+tcp://prl.kryptex.network:7048 --wallet WALLET_ADDRESS --worker WORKER_NAME
lpminer setup for PRL
lpminer (Nvidia) is the simplest option on Windows:
lpminer.exe --algo pearl --pool stratum+tcp://prl.kryptex.network:7048 --wallet WALLET_ADDRESS.WORKER
All of these miners run on HiveOS with ready templates. Full step-by-step setup: 👉 How to mine Pearl (PRL).
