Kết nối
How To Mine DigiByte DGB
11/5/2026
Check our YouTube Video how to mine DigiByte DGB
DigiByte (DGB) is an open-source cryptocurrency launched in 2013. Blocks are generated every 15 seconds, making it 40 times faster than Bitcoin. The project is fully decentralized — there was no ICO or foundation, and it is entirely community-driven. DigiByte uses five mining algorithms, significantly enhancing its security. It also incorporates DigiShield, SegWit, and DigiAssets — tools for creating smart contracts and digital assets — making it one of the most advanced blockchains.
Kryptex Pool supports mining DigiByte DGB using various SHA256 ASIC devices. GPUs and CPUs, however, aren't capable of mining DigiByte DGB, as they simply lack the necessary processing power.
Kryptex Pool uses PPS+ and SOLO payout scheme.
Supported miners
Kryptex DigiByte DGB Pool supports all well-known miner manufacturers:
  • Bitmain Antminer
  • Whatsminer MicroBT
  • Canaan Avalon
  • Innosilicon
  • Aladdin
  • Bitfury
  • Ebang
  • Aixin
Create An DigiByte DGB Wallet
To start DigiByte DGB mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
    • URL of the DigiByte DGB mining pool: stratum+tcp://dgb.kryptex.network:7037
    • For instance: DNvHkaYfCCDjHjBo6HeF1ibedZZBCed8kN.Antminer_S21 where: DNvHkaYfCCDjHjBo6HeF1ibedZZBCed8kN — represents the DigiByte DGB wallet address. Antminer_S21 is the chosen name for your worker in free form.
    • Ensure you use a DigiByte DGB wallet address.
  1. Visit the DigiByte DGB Kryptex Pool at **https://pool.kryptex.com/dgb.**
Payouts
  1. Open the DigiByte DGB pool page and enter your mining address;
  5. Press the “Submit” button.
