How To Mine Zcash ZEC
15/9/2569
Check our YouTube Video how to mine Zcash ZEC
Zcash (ZEC) is a cryptocurrency designed as a privacy-focused alternative to Bitcoin, with a strong emphasis on anonymity and security. It’s built on the zk-SNARKs protocol, which enables shielded transactions — hiding the sender, receiver, and transaction amount. Zcash doesn’t aim to replace Bitcoin, but rather offers a choice for those who value confidentiality in digital payments. The developers are actively engaged with the community, continuously supporting ecosystem growth and implementing new innovations.
Kryptex Pool supports mining Zcash ZEC using various EquiHash ASIC devices.
GPUs and CPUs, however, aren't capable of mining Zcash ZEC, as they simply lack the necessary processing power.
Supported miners
Kryptex Zcash ZEC Pool supports all well-known miner manufacturers:
- Bitmain Antminer Z9mini, Z9, Z11, Z15, Z15Pro
- Innosilicon A9, A9+, A9++
Create Zcash ZEC Wallet
To mine Zcash ZEC, you willl need a wallet address.
You can create a personal Zcash ZEC wallet using convenient multicurrency wallet TrustWallet, or get a wallet address from a cryptocurrency exchange MEXC, Binance, Gate.io, KuCoin.
For mining and long-term storage, we strongly recommend using a personal wallet.
Mine Zcash (ZEC) — get paid in Bitcoin (BTC) directly to your Kryptex account. Your ZEC earnings are automatically converted to BTC. You can withdraw your crypto in multiple ways: BTC, ETH, LTC, TRX, BNB, USDT, USDC — or to your Volet wallet.
Connecting to the Zcash ZEC: Step-by-Step Guide
| Region | URL | Wallet Template | Password |
| Global | zec.kryptex.network:7042 |
wallet.worker |
x or leave blank |
| EU | zec-eu.kryptex.network:7042 |
wallet.worker |
x or leave blank |
| US | zec-us.kryptex.network:7042 |
wallet.worker |
x or leave blank |
| SG | zec-sg.kryptex.network:7042 |
wallet.worker |
x or leave blank |
| RU | zec-ru.kryptex.network:7042 |
wallet.worker |
x or leave blank |
Let's take the Bitmain Antminer Z15 Pro ASIC as an example.
Access the control panel of your ASIC.
Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
Input the following settings:
- URL of the Zcash ZEC mining pool:
stratum+tcp://zec.kryptex.network:7042 - Worker: Enter the wallet address for mining and the worker name in the format
t1ScU9R3YoZWPwwrm2jGSZtTpHKk9tw6ahU.Z15where:t1ScU9R3YoZWPwwrm2jGSZtTpHKk9tw6ahU— represents the Zcash ZEC wallet address.Z15is the chosen name for your worker in free form. - Ensure you use a Zcash ZEC wallet address.
- Password: This field is optional. You can either enter
xor leave it blank.
If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
Save and apply the settings, then reboot the ASIC.
Visit the Zcash ZEC Kryptex Pool at https://pool.kryptex.com/zec.
Payouts
Open the Zcash ZEC pool page and enter your mining address;
Press the “Settings” button.
Press the “Submit” button.
