How To Mine eCash XEC
20/5/2569
Check our YouTube Video how to mine eCash XEC
eCash (XEC) is a cryptocurrency built on Bitcoin ABC, rebranded in 2021. It leverages the Avalanche protocol for fast and secure transactions, supports tokens and NFTs. Focused on scalability and user-friendliness, it’s ideal for DeFi and applications. Leading exchanges endorse the coin, and miners appreciate its high profitability.
Kryptex Pool supports mining eCash XEC using various SHA256 ASIC devices.
GPUs and CPUs, however, aren't capable of mining eCash XEC, as they simply lack the necessary processing power.
Supported miners
Kryptex eCash XEC Pool supports all well-known miner manufacturers:
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Aladdin
- Bitfury
- Ebang
- Aixin
Create An eCash XEC Wallet
To start eCash XEC mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
Access the control panel of your ASIC.
Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
Input the following settings:
- URL of the eCash XEC mining pool:
stratum+tcp://xec.kryptex.network:7036 - Worker: Enter the wallet address for mining and the worker name in the format
ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9.Antminer_S21where:ecash:qqnfdqprcv4sk9cuhy9ga7lctkarh94aayqcqncau9— represents the eCash XEC wallet address.Antminer_S21is the chosen name for your worker in free form. - Ensure you use a eCash XEC wallet address.
- Password: This field is optional. You can either enter
xor leave it blank.
If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
Save and apply the settings, then reboot the ASIC.
Visit the eCash XEC Kryptex Pool at https://pool.kryptex.com/xec.
Payouts
Open the eCash XEC pool page and enter your mining address;
Press the “Settings” button.
Press the “Submit” button.
