How To Mine DigiByte DGB
21.04.2025
DigiByte (DGB) is an open-source cryptocurrency launched in 2013. Blocks are generated every 15 seconds, making it 40 times faster than Bitcoin. The project is fully decentralized — there was no ICO or foundation, and it is entirely community-driven. DigiByte uses five mining algorithms, significantly enhancing its security. It also incorporates DigiShield, SegWit, and DigiAssets — tools for creating smart contracts and digital assets — making it one of the most advanced blockchains.
Kryptex Pool supports mining DigiByte DGB using various SHA256 ASIC devices. GPUs and CPUs, however, aren't capable of mining DigiByte DGB, as they simply lack the necessary processing power.
Kryptex Pool uses PPS+ and SOLO payout scheme.
Supported miners
Kryptex DigiByte DGB Pool supports all well-known miner manufacturers:
- Bitmain Antminer
- Whatsminer MicroBT
- Canaan Avalon
- Innosilicon
- Aladdin
- Bitfury
- Ebang
- Aixin
Create An DigiByte DGB Wallet
To start DigiByte DGB mining, you should have a wallet address. You can create your wallet or obtain a wallet address from a cryptocurrency exchange.
Access the control panel of your ASIC.
Navigate to the settings section, typically labeled "Miner Configuration" or "Settings".
Input the following settings:
- URL of the DigiByte DGB mining pool:
stratum+tcp://dgb.kryptex.network:7037
- Worker: Enter the wallet address for mining and the worker name in the format
Wallet_Address.Worker_Name
. The worker's name should comprise numbers and Latin letters, excluding spaces or special characters. - For instance:
DNvHkaYfCCDjHjBo6HeF1ibedZZBCed8kN.Antminer_S21
where:DNvHkaYfCCDjHjBo6HeF1ibedZZBCed8kN
— represents the DigiByte DGB wallet address.Antminer_S21
is the chosen name for your worker in free form. - Ensure you use a DigiByte DGB wallet address.
- Password: This field is optional. You can either enter
x
or leave it blank.
If needed, replicate these settings across all three profiles. This ensures that the ASIC will reconnect to the pool and resume operations in case of a connection loss.
Save and apply the settings, then reboot the ASIC.
Visit the DigiByte DGB Kryptex Pool at **https://pool.kryptex.com/dgb.**
Payouts
Open the DigiByte DGB pool page and enter your mining address;
Press the “Settings” button.
Press the “Submit” button.
