How to create ETHW wallet
15/12/2022
There is currently no separate wallet for ETHW.
However, we can easily add ETHW to the Metamask wallet.
  1. Register Metamask.io wallet if you did not have one
  2. Log in to your wallet
  3. Open your account settings and press “Add Network
  4. Enter the data for a new network:
  5. Save your network. Copy your wallet address. Use it for your miner.
Notes:
  • Metamask uses the same keys for all Ethereum-based coins, so your address may be the same as for Ethereum. This is OK.
  • If there were coins on your ETH wallet before the POS, they will be also available on ETHW wallet.
Questo articolo è disponibile in altre lingue:
