Start mining
  • Global
    xtm-c29.kryptex.network:7040
  • Europe
    xtm-c29-eu.kryptex.network:7040
  • North America
    xtm-c29-us.kryptex.network:7040
  • South America
    xtm-c29-br.kryptex.network:7040
  • Singapore
    xtm-c29-sg.kryptex.network:7040
  • China (Hong Kong)
    xtm-c29-hk.kryptex.network:7040
  • Russia
    xtm-c29-ru.kryptex.network:7040
  • Middle East
    xtm-c29-ae.kryptex.network:7040
  • wallet/worker
  • or
  • username/worker
Use solo:wallet for SOLO mining
Start mining
In order to protect our PROP miners, rented hashrate like NiceHash or MRR is automatically switched to SOLO mining.
Start mining Tari Cuckaroo29
  • Windows
  • Linux
  • HiveOS
  • MMPOS
Mine XTM, receive USDT
Use username as a wallet to get:
  • BTC, USDT, Volet, and even gift card withdrawals
  • Instant withdrawal as soon as you reach $1
  • Get payouts in Bitcoin instead of XTM
or
Create a wallet for your coin
Exchange your coin
Configure your miner
Mine on:
Region
Wallet
Worker
SSL
SOLO
Start mining
  • Extract the miner archive to a convenient place, and open the resulting folder with the miner in it.
  • Create a text file with a .bat extension and place a command in it to launch the miner that you have downloaded.
  • LolMiner
  • BzMiner
  • Blockz-miner
  • Supports AMD, NVIDIA and Intel Arc GPUs
  • Dual and split mining out of the box
  • Overclocking support
Download the miner
lolMiner.exe --algo CR29 --pool xtm-c29.kryptex.network:7040 --user <wallet>
Save the changes and run the file. Done!
Custom share difficulty
Tari Cuckaroo29 pool has a static difficulty of 20.
Custom difficulty is not supported. Contact support if you need help.
Video Guides
Video Guides
We speak the same language with the miners.
We will help you solve any problem. We help with the equipment, configuration and scaling of any kind.
