ASIC Bitmain Antminer KS3
07/07/2023
Bitmain has recently introduced their newest innovation, the Antminer KS3. This cutting-edge ASIC miner is specifically engineered for efficient mining of kHeavyHash KASPA.
If you're in search of a reliable mining pool for your Antminer KS3, we highly recommend Kryptex PPS+ Pool.
We offer full support of Antminer KS3 ASIC, so you can expect exceptional efficiency and a consistent profit when mining KASPA.
Join us today at https://pool.kryptex.com/kas
Antminer KS3 — Characteristics and Size
Manufacturer — Bitmain
Model — Antminer KS3
Algorithm — kHeavyHash
Coins — KASPA
Hashrate — 9,4 Th/s (9400 Gh/s) ±10%
Power Consumption — 3500 Watt ±10%
Dimensions — 43 х 19,5 х 52,9 cm
Weight — 16,1 kg
Antminer KS3 Hashrate
Antminer KS3 ASICs’ can make 9,4 Th/s (9400 Gh/s) ±10% on kHeavyHash (KASPA) algorithm, which is equal to the hashrate of 3910 graphics cards Nvidia RTX 4090, consuming 280 times less electricity — only 3500 watts versus 977 500 watts.
What to Mine on Antminer KS3?
Bitmain Antminer KS3 can only mine KASPA coin and kHeavyHash algorithm. You can’t reconfigure it for any other algorithms.
Antminer KS3 Profitability
Currently, the daily profitability of Antminer KS3 ASIC is about ~ 440$, excluding electricity costs.
Profitability can sharply decrease with the increase of the KASPA network difficulty.
Check the profitability of Bitmain Antminer KS3 ASICs on the mining calculator.
Antminer KS3 Settings
Go to “Settings” tab to setup your ASIC.
Coin | Mining Address | Miner Name | Password |
KASPA | stratum+tcp://kas.kryptex.network:7777 |
x or leave blank |
kaspa:qp8u4wzjhy5m8h63cz7kvczpdksd3cqghptf5nakghmue5ffqlvyusw30dgpg.bitmain
where
— your wallet address, starting withkaspa:
bitmain
— Your ASIC name.
Antminer KS3 Firmware Update
Go to the manufacturer's website and download the required firmware: https://shop.bitmain.com/support/download
Open the page for updating “Firmware upgrade”, select the downloaded update.
